So I just got my new setup finished and I'm experiencing a really annoying bug that pretty much ruins the purpose of my newly acquired second monitor: Twitch/YouTube has these strange lagspikes every couple of seconds, as if the streamer is dropping frames. As soon as I move the Chromewindow with the stream on it to my primary monitor, the problem stops. Furthermore, running a Twitch stream in their old Flash-player (but not in fullscreen) seems to fix the issue, but it's a very clunky solution. All drivers are up to date.
My setup consists of:
- Windows 10 Pro
- BenQ XL2420T at 120 hertz.
- Samsung S24E450 at 60 hertz.
- MSI GTX 770 2 GB.
- i5-4670k at stock clock with turbo enabled.
- 16 GB DDR3 ram.
- ASUS Z87 motherboard.
What I've tried:
- Switching off the second monitor completely so that the stream runs on the primary monitor: Solves the problem.
- Changing the cable used for the second monitor: No effect.
- Disabling Flash's Hardware Acceleration: No effect (shouldn't anyway since Twitch's new player runs HTML5).
- Monitoring CPU/GPU/RAM/VRAM load: None are maxed, though the CPU sits at around ~50% usage, but that seems to be normal with HTML5 videoplayers.
- Setting both screens to run 60 hertz: Seems to slightly improve performance, but still not optimal at all.
- Downgrading to an older graphicsdriver: No effect.
- Tried with a different secondary monitor: No effect (which could conclude that it's a driver/OS/GPU problem).
- Cleaned PC: No effect.
- Removed the 2 2x4GB ramsticks that I put in at the same time as installing the new monitor: No effect.
Running the Livestreamer application for Windows that plays the videostream in VLC fixes everything, too. Again, very clunky solution.
I'll paypal whoever finds me the solution $20.
I hope that someone has ideas to what I could try, this has been driving me up the wall for the past couple of hours.
Thanks!
- Windows 10 Pro
- MSI GTX 770 2 GB.
- 16 GB DDR3 ram.
What I've tried:
Thanks!
