Strange grinding noise
Permabanned
18 Oct 2002
Lost!
Mum has had a CV joint done on her passat, they also replaced an ABS sensor on the other side which had failed.
Since the work was done, when braking as you just get to a halt, approx 2-4mph there is a horrible grinding noise. This doesnt happen at higher speed, there is no indication of anything being lose and visual inspection everything seems in place.
Any ideas??
Nope, looked at stone guards, pads, and calipers all seem fine. Removed, refitted and torqued the wheels so not that.
It doesnt happen at any speed other than a crawl to a halt and then out the blue is the noise!
Take it back and get them to look at it?
Something must be moving under braking to make the noise, possibly the ABS ring or sensor catching something I'd imagine.
