Hi as the title says I have come across a strange HDMI related issue.
My dad recently purchased a new samsung Blu-Ray player. I cannot remember the model number right now but it supports 3D content so it must adhere to the HDMI 1.4 standard (if I am understanding things correctly?).
He has plugged it in, via HDMI, to his 1080p samsung television (3 or so years old now - purchased before 3D televisions existed so I assume it uses the 1.3 HDMI standard or below).
The first cable he used was an HDMI 1.3 cable (not sure of the exact revision). The output was fine at 480p / 720p / 1080i, but attempting to output at 1080p from the player resulted in a blank black screen on the television. No amount of settings changes could correct this.
He then swapped the cable for an HDMI 1.4 cable (which I leant him) and the output over 1080p worked perfectly.
My question then, is why?. To the best of my knowledge there should be no good reason why the 1.3 revision cable shouldn't work for 1080p 2D output. Both cables are 1.5m in length. The first cable is a bush cable purchased for £12. The second cable i purchased for £1.50 from ebay. So quality shouldnt be an issue?
Any opinions / theories would be appreciated. This is more to satisfy my own curiosity than anything else.
