- 12 Dec 2006
as of late my laptop had been running a little slow so i loaded cpu-z to check the settings......
the T5750 which should be running a 2.0ghz 166fsb*12.
But its running at 999mhz to 2000mhz constantly changing the multi anywhere from 6 to 12. ive checked it with many diferent cpu programmes all saying the same.
how is this possible?? is it a hardware fault? how to fix?
the T5750 which should be running a 2.0ghz 166fsb*12.But its running at 999mhz to 2000mhz constantly changing the multi anywhere from 6 to 12. ive checked it with many diferent cpu programmes all saying the same.
