Just helping someone out with their internet connection. They're going to migrate, so was thinking about Max: the stats given by their Linksys WAG54Gv2 router sound so implausible that I doubt they're based on anything real:
Downstream Rate: 1152 Kbps
Upstream Rate: 288 Kbps
Downstream Margin: 0 db
Upstream Margin: 6 db
Downstream Line Attenuation: 46
Upstream Line Attenuation: 23
Downstream Transmit Power: 0
Upstream Transmit Power: 0
I'd find it unlikely that a line of 46dB attenuation would have a particularly low SNR... but even less likely that a line with a constant 0dB margin would've been completely stable for over a year.
Any opinions? Should I just junk them, go for Max and see what happens? Not got anything else to test the line with, unfortunately. No extension wiring present - just a filter with fax & dsl.
EDIT: Rebooted it a couple of times. It now varies between 0 and 2147483647 db. Not seen anything else!
I don't see how it could stay connected with a downstream SNR margin of 0dB. Perhaps updating the router firmware would give more realistic figures?
