This has been happening ever since I installed WoW on my Macbook on Thursday, this problem has also remained after a complete reinstall of OSX.
Basically I can load up WoW, login and play no problem but after about a minute, sometimes shorter the framerate will drop to 3-5fps and stay like it. The normal framerate averages about 20fps normally. The framerate drop is instant, from 20 down to 3, I can be standing still or moving and it will do it. I investigated my CPU usage during this and saw the following results.
The red box shows when WoW is running fine with a high average FPS, the bit in the midle shows when it screws up and runs at a low FPS and the yellow box shows the activity when I close WoW.
I should also mention that if i let the computer go into standby or shut it down then power it on again, I can load up WoW and it'll be fine for another minute or so, re-loading in the same session will cause it to still have low FPS which is visible from the title screen too.
Any idea's I'm new to OSX so I don't know the best way to investigate a problem like this.
) but could it be the cpu throttling due to heat (or similar)?
