Hi, so Im trying to run memtest on my new SB system. Specs are:
i5 2500K
P8Z68-V
Corsair Vengeance 1600C8.
All is up and running at proper voltages and timings and I have a nice stable overclock of 4.5ghz on the CPU. However, when I try and run memtest from bootable usb, it only detects the bclk as 73 and not 100, causing all the memory frequencies to be a lot lower than when in windows. And ofcourse it's pretty pointless stresstesting at that lower speed if I want to use it faster.
Any ideas in the bios where I can set it to detect correctly? The CPU doesnt even show 4500mhz on POST, just 3328 or something strange, but in windows is fine.
Thanks, the bios is literally the same as the P8P67 if any of you owners can help.
Cheers
i5 2500K
P8Z68-V
Cheers
