Hi,
The car in question is a Ford Mondeo 2.0 Petrol Zetec, on a 51 plate.
The car itself is sound apart from one fault, which I've noticed this evening.
Driving towards town (about 15 miles away), I noticed that the temperature gauge hadn't moved, it was sitting on the bottom. I had the aircon on, albeit at an average temperature (somewhere in the middle of the gauge). As soon as I turned the aircon off and kept the temperature the same, the temperature gauge came back up to the middle (as it should). I stopped the car and turned the engine off. When I restarted, the idle was around 1200rpm, as if the car was cold (it had already been driven 11 miles).
Playing with it a bit more, I noticed a correlation between the aircon being on, and the position of the temperature gauge.
Would I be right in thinking this is an electrical issue, rather than mechanical? When the temperature need dropped, it did so very quickly - its not possible for coolant temperature to fall that fast!
Hence my thought being the coolant temperature sensor at fault.
Any ideas?
Cheers
Any ideas?
Cheers
