Hi guys now iv mentioned this before in the bf2 thread but knowone seems to pick up on it and this problem seems to happen to me everytime i play bf2 now..
Its an interesting little bug this but its a very annoying one aswell! i hope someone else gets this so i can try and work out whats doing it!
The problem i get is normally when im scoping, I put it into scope and sunddenly it starts moving around without me even touching the mouse, the movement going around in circles sometimes and other times its going up and down. It does this weather im prone or standing. Then when i come out of scope it still does it untill i either wait for it to stop or i go into scope again (sometimes it carries on for the whole round) I call this scope bug btw because it only ever does it when i use the scope..
I also suffer from the movement to be very coppy sometimes aswell, Its hard to explain but the only way i can explain is when i pan left or right it 'misses' a chunk and makes it jerk the rest of the way (big jumps in movement) my fps never drops below 80 fps so it cant be gfx lag can it? Would this be anything to do with playing on a TFT? Its a Viewsonic VP101 i think is the name (its a 17" 8ms)
My bro said to me last night that he thinks its just me because neither him or my other bro get this, he thinks its my mouse, but i get it with my mx510 & IE 3.0.
spec
p42.8OC3.5
6800 ultra
1gb ram
all my settings are set to low and running on 1024x768
I hope someone understands what im talkin about, if so you might be able to give a better example of what happens.
Thanks
spec
p42.8OC3.5
6800 ultra
1gb ram
Thanks
