Strange network slowdown ...
23 Apr 2007
Cardiff-ish, Wales
Hi guys,
I have three PCs (Jed PC, Bec PC, SERVER) in my computer room, all with gigabit connections, cat 6 cable going in to a gigabit switch.
Recently things have taken a strange turn.
When I copy from Jed PC to Server I'm getting around 10KB/s.
When I copy from Jed PC to Bec PC I'm getting around 10MB/s.
When I copy from Bec PC to Server I'm getting around 10MB/s.
Any idea why it's so slow from Jed PC to Server, when it's fine from Jed PC to Bec PC and also fine from Bec PC to Server???
EDIT - also tested:
When I copy from Server to Jed PC I'm getting around 10MB/s.
It seems like the issue is one way from Jed PC to Server, not the other way though ...
Ahhh yeah:
Jed PC Vista Home Premium 64bit
Bec PC Vista Ultimate
Server Windows Home Server
All with the latest service packs and updates. It's only recently started playing up - it was fine before.
Check the error counters on the NICs. If it's only happening one way you could have dodgy termination on a pair in the cable. though this should affect all connections in that direction.
for gigabit 10MB/s is rather slow. What spec is this server?
Usually slow speeds are a result of duplex mismatch, but again should be the same both ways.
Thanks guys. I'll check the wires in the morning. Personally, I've been having some strange drop-outs recently and I'm leaning towards the problem being the switch ... I'll do some testing in the morning.
Server is an Athlon 4600, 2Gb RAM - shouldn't be an issue ... what speeds should i be seeing on a gigabit network?
I get 80Mb/s from my server to HTPC, yet I get 3MB/s going back the other way!!
Server is running 3 WD Green 1TB drives in RAID5, the HTPC is running 1 WD Green 1TB in RAID0 mode.
Still having trouble guys. I've changed the switch and cables and I'm still getting the problem. However, if I reset my network card through Control Panel then I then get a decent 50Mbs. This doesn't last too long though and reverts back to 30Kbs, certainly within a few hours. Again, if I reset the card then the speed goes back up. Any ideas???
I'd drop a good quality PCI card in and see if that help - if you can't find your card I'll happily chuck an Intel Pro1000 GT adaptor in the post for you.
Single drive RAID0 O.o that's a new one on me.
It's looking like the NIC though the fact it works for a while then degrades is most odd.
Have you completely re-installed the drivers?
