Strange not charging, poor performance problem with ASUS TUF 15 laptop
22 Mar 2024
Norwich, UK
ASUS TUF 15 (FA506II model) laptop 2021.
The laptop will run well when on battery (not plugged in) but the battery will only last a maximum of 2 hours. When it's plugged into the mains, performance is severely affected - extremely slow running any game, struggles with most tasks - and the battery does not recharge. The battery won't charge when the laptop is in use and only recharges when the laptop lid is closed and is hibernating or turned off and takes several hours to recharge fully. I've tried every power management setting, diagnostic tool (performance, battery, RAM etc) with no errors, battery is healthy and Armoury Crate doesn't seem to be able to change anything. I've even tried booting from an OS on a USB, using the RAM and it behaves exactly the same. Also, I've run it without the battery and it booted with normal performance but after about 5 mins it went back to the same poor performance.
So I guess that suggests it's a hardware issue? Has anyone experienced anything similar to this? Any help or suggestions would be appreciated!
This sounds like the PSU isn’t supplying the right wattage, so the laptop is throttling to react to the supply. Lots of Dell and HP laptops act this way when a lesser model’s charger is attached (say 45W connected to a 65W laptop).
I’d suggest trying another charger.
