- 28 Jan 2005
- Southport
Hi all,
Ive been with O2 for a good while now and over the last few months ive been having connection problems. Very strange tho..
I can always remote into my pc from work no problems but I sometimes cannot browse the web from it. Using my computer at home I can use MSN no problem again but sometimes cannot browse any websites at all.
The way I can fix it is either reboot the router (DG834GT) and release and renew the IP from the connection status. Ive tired all sorts. Ive had the DNS servers manual and automatic, no difference.
Its bugging me now really. Im on the 16mb package and seem to connect at 13-13.5mb. Reading up a bit I found that the downstream Noise margin will go as low as 5.6
Not sure if this is affecting it, just strange that I can always remote into my pc.
Thanks for your help
Pete
Pete
