Strange OneDrive issue
26 May 2009
Hi everyone,
I'm having a very bizarre issue with OneDrive, basically it all works fine except the OneDrive shortcut for my personal OneDrive in the File Explorer tree does nothing. I click on it nothing happens, if I right click properties it's all blank. I'm having to go to the folder via a pinned shortcut in quick access.
I also have a corporate O365 OneDrive, and if I add that I get the company OneDrive shortcut in the tree too but that works fine, just the personal one that doesn't work. I have tried uninstalling/reinstalling OneDrive, installing to a different folder, no joy. What did "work" was uninstalling OneDrive and then reinstalling it using an old installer, which worked fine until OneDrive updated to the latest version then it stopped working again.
From the way the shortcut appears to be empty when you right click properties on it I assume it's just some info missing from a config file or a registry entry somewhere, but Google seems to offer no similar issues.
Any ideas?
