Ok so I have been playing around with my overclock again
I was running my E6600 at 3.1ghz quite happily and the g.skill hz ram at stock speeds (4-4-4-12 T1 800mhz)
That worked fine, passed ram and cpu stress tests all day long
But I have found as soon as I push past this, say to 3.2ghz, 3.3ghz etc it all falls apart.
According to Orthos its the ram... even tho this is running at stock speeds and passes memtest
It passes all the CPU stress tests fine, but when you include a ram stress test it freezes after a few minutes
I have tryed increasing the ram voltage to the max safe 2.2volts but this has no effect
How can my ram be holding back the system when im overclocking the CPU, i am using a divider on the EVGA board so the ram is staying at 800mhz
