Hey All,
Just after some help if possible, basically the problem started when I accidentally half knocked out the Plug for my PC from the extension lead, I hit it and the plug was half in half out and it shut down my PC and I thought Oops.... as you do, Went to turn PC back on after re-seating the mains plug and it would not come on.
The motherboard would not beep, neither of my screens would display, all that would happen is, CPU Error LED would stay red on the motherboard and fans would light up but that is it.
I left it over night as I tried everything I could think off removing all components resetting BIOS/CMOS all the reset buttons on the motherboard and nothing, still same issue.
In the morning I tried it and it worked.... and it has been working since and this was couple of weeks ago but this exact same error always now happens after the PC being in use, I can use my PC all day or all weekend but as soon as I turn it off it will not power back on with the same issues as above unless I leave it over night... almost like it has to cool down or something. I have zero issues whilst PC is in use, it's just when I turn it off it has to stay off for 8-9 hours before I can turn it on again.
This happened either at same time as I knocked the plug out or since I have installed a H115i Corsair cooler.
Just wondered if anyone may have any ideas what this issue could be as its quite annoying
Thanks in advance.
Motherboard: ASUS Sabertooth 990FX R2.0
CPU: AMD FX 9370
GPU: EVGA 980Ti
Power Supply: Corsair RM1000
Thanks in advance.
CPU: AMD FX 9370
GPU: EVGA 980Ti
