Strange performance in Crysis Warhead
26 Jul 2005
Basically ive just installed Crysis Warhead and I've used UltimaRages CCC Performance Tweaks. Ive used the lowest level - level 3. The problem is, when I first load into the game I get really nice fps 30+ however it seems to slow down with time. Also, when theres a lot going on it really really stutters.
Im wondering what could be the cause of this, as soon as I alt tab out and in the game it returns back to normal performance.
Is there a problem or is my pc just too old now :D
Intel Pentium D 805 @ 3.8ghz
Evga 8800gts 320mb superclocked
evga 650i
hiper ps (530W i think)
cheers
Sounds like a memory leak somewhere..
How much ram do you have, what other applications are open in the background, and have you patched Crysis to the latest available patch?
With only 2GB RAM and 320MB VRAM, made sure you turn the texture quality down. FWIW I found that memory usage was much lower in DX10 mode than DX9 in Crysis.
