Hi all,
I've recently been given my Dad's old Plasma TV. We couldn't get a display on either of the HDMI ports with my Sky box, or my PS3, and eventually discovered the problem - the TV doesn't seem to work when devices are set to 1080p. We changed the setting on my Sky Q box from 1080p to 1080i and it works.
Same with the PS3, wouldn't display anything, so I connected the console to a different TV that it does work with and change the resolution from 1080p to 1080i. Connected it back to the Plasma and it works fine.
This is really odd because the TV is a Panasonic Plasma TX-P50U30B and in the manual, and all adverts etc. it says that it supports 1080p.
So why will it not work when the devices connected are set to 1080p?
edit - my amazon firestick wouldn't work with the TV in 1080P either... I had to change the setting on the firestick menu to display in 720P and it works fine.
Amazon firestick resolutions are 1080p 60hz, 1080p 50hz, 720p 60hz, 720p 50hz.
Might help someone else out who has come across this too...
I'd still like to know why a 1080P TV set can't display devices in 1080P resolution though.
