- 3 Jan 2014
My PC has suddenly started behaving strangely when powered on. It runs the POST, reboots, then says that it failed to boot. When I go in to the BIOS I noticed that the DRAM voltage is reading at 1.5v. If I save and exit without making any changes, it boots absolutely fine. If I go back in to the BIOS the DRAM voltage shows 1.656v (which is the correct voltage(?) for my RAM). The XMP profile sets the voltage at 1.65v, but for some reason on a cold boot it seems to be ignoring it, and fails, but after rebooting it's set properly and everything works properly.
Has anyone experienced anything like this before, or have any ideas as to what the problem might be?
Gigabyte z97x SOC Force (F8 BIOS)
i7 4790k (No overclock)
16GB DDR3 Team Group Vulcan Orange (2133MHz)
