Hi all,
Really Strange one for you,
My PC will no longer power up, I turned it off last night as usual, and I go to switch it on and nothing! I have tried to reconnect anything that seemed loose, but nothing was!!!
In the past few weeks the computer sounded like it shut down but screen was still on (no lights on the case etc.), randomly.
Specs are as follows:
Hiper TypeR 480w PSU
Asus A8N32-Sli Deluxe
AMD Athlon 4200+
2x 512 Twinmos Ram
1x Generic Ram
1x 80gb hdd
1x 120gb hard drive
Unfortunately I cannot find my 20-24 pin adapter so cant test if its the PSU.
Thanks in advance
AMD Athlon 4200+
2x 512 Twinmos Ram
1x Generic Ram
1x 80gb hdd
1x 120gb hard drive
Thanks in advance
should have read your post properly, watching TV and reading the forums don't go well
