Strange problem and im not sure what with......
13 Dec 2002
Newcastle upon Tyne
Spec is as in sig:
this appears to be an intermittent fault that can happen a few times in a evening then nothing for a week or so.
PC runs brilliant but if i leave it on and go away for a bit the screen goes into standby and sometimes wont come back, if i swap the dvi lead to vga and swap my source it comes back to life but the vga is fuzzy slightly compared to dvi (not sure if thats normal) at first i thought it could be my 470 but i tried a different card and had the same issues so im not sure if its a fault with my lcd/tv, thats a samsung syncmaster sm2333. The other odd thing is when the display goes black if i press and hold my powerbutton to shut it down it shuts down and then reboots by itself.....
If i switch the psu off and then on and press the power it works fine again so im at a little bit of a loss as to what the problem could be
Any one had anything similar?
