Strange problem GA-MA790XT-UD4P
21 Sep 2008
Hi guys i recently brought this board GA-MA790XT-UD4P but its acting strange as when you first start up computer it will say amd data changed updating dmi data and then computer will restart and go back to bios say the same again and then go to screen were it says windows was not shut down properly so i tell it to start windows manually then it restarts computer and then goes back to windows was not shut down properly but this time when i tell it to carry on it will go in to windows and be fine.
once in windows its fine its just getting there in the first place thats a bit of a pain also having probs with lan port not always working.
Have you tried flashing it with the new bios? Try it, if it still doesn't work properly, then I think you need to RMA it....
