Hi guys, hope everyone is doing good!
I'm having a weird problem with my pc, started a few days ago, out of the blue. Basically I'm getting hangs/freezes, but mouse pointer still works, and pc is semi-active, but it won't actually do anything.
At first I thought it was NVidia driver issue for the GTX400/500, but I'm not so sure now, as I've had no problems with it for months and it's not saying the driver has crashed like it did before.
It will actively stop responding when in a game or web browsing, and it will also do it just sat on the desktop for a while. Alt tab does nothing, and cntrl+alt+del makes the screen go black, then a box appears saying "windows was unable to load security options" (or something very similar), click the close button and it just stays black, the only thing you can do when it stops is force a shutdown (hold power button). There are no errors, or events logs for it at all, except the unexpected loss of power when you startup again.
I've tried messing with the NVidia drivers, installing the newest (which made it worse) and re-rolling back. I've even done a complete re-install with windows 8 and tried both old and new NVidia drivers, still same issue.
PC has (no overclocks):
Windows 7 SP1/ Windows 8 (tried both)
i7 2600K 3.4Ghz
Corsair XMS3 8GB 1600Mhz
Gigabyte P67A-UD4-B3 Mobo
Gigabyte GTX460 SOC
Crucial M4 SSD 128Gb
Seagate Barracuda 1TB 7200
OCZ Stealthxtreme 2 600W supply
Benq G2420HDBL Monitor
Thanks for your help
i7 2600K 3.4Ghz
Gigabyte GTX460 SOC
I've done another reinstall back to Win 7, and had no problems for 24hrs.
