So, Christmas Eve, booted fiancee's PC and there was a horrible crackling noise followed by the smell of burnt electronics.
I immediately shut off all power to the rig - from the smell the PSU was fried and there were no obvious problems with the rest of the system (no burn marks, the burnt electrics smell was localised to the PSU.)
I went to the local store and bought a new PSU. Got home replugged everything in but the system would not boot. Graphics card seems to be getting power - red lights on the 8 pin power connectors when the PSU connectors are not plugged in and green when the are - which suggested to me that power is getting to the board otherwise the GPU would not have any power for the LEDs. But no beeps, drives do not spin up, optical drive has no power to open it and no fans power up.
So I figured it must be something to do with board - I tested the RAM and GPU in my own rig, no problems. I didn't test the CPU because both mine and my fiancee's have AIO liquid coolers attached so it would be a pain in the ass plus I figured a damaged CPU should not prevent the fans/drives from spinning up.
So I went out and bought a replacement motherboard today - fitted everything back together - still nothing. The GPU is getting power as before but no drives/fans spinning up.
Now I am not in a hurry to go out and buy a replacement CPU only to find out that that is not the problem either so I was wondering if anyone can confirm if a blown CPU can prevent the fans/drives from spinning up? Still no beeps and the manual for the motherboard is just terrible (Gigabyte 970A-DS3P) with zero troubleshooting info and I can't see any LEDs on the board to diagnose with either.
Could it be the power switch on the case? Is there a safe way to test the power switch? I plugged the reset switch leads into the Power Switch Connectors on the motherboard and held in the reset button to see if it would help but still nothing, I presume it would at least attempt to boot until I take my finger off the button - which makes me think it is not the power switch.
I am truly stumped, in the past whenever I have had issues at the very least the fans spin - to have no response at all is really confusing me.
Any help appreciated.
