- 7 Aug 2010
Hi, I'm hoping for some advice with an issue with a new build.
All new parts used apart from GPU but tested as working fine.
Asus tuf Z690 D4
Intel i5 12600k
Corsair RM850 psu
Corsair vengeance lpx 32 GB ram
Nvidia founders edition RTX 3090 (bought used)
Basically everything works as it should until I plug in the GPU power. It boots up just fine when using onboard graphics. I've tested the 3090 in another PC and it's fine, I've also tried a working 3060 and this causes the same proplem in this build.
It fires up and runs with a GPU in the slot as long as it isn't connected to power. I've tried two different power GPU power cables.
I've checked PCI is set to enabled in the bios.
My thoughts are a faulty PCIe slot on the MB, is that plausible, I've always used Asus as they are top quality.
Any ideas most welcome.
Asus tuf Z690 D4
Intel i5 12600k
Corsair RM850 psu
