- 4 Oct 2011
Hi guys
Recently bought a "Titan Spinosaur" Rig from OCUK, everything has been great with it, however I have noticed when turning it on sometimes, it does not post to windows... I get a little cursor in the top left hand corner of dos and it hangs there.., sometimes when turning it on it turns itself off after like 5 seconds and then turns it self back on again. I have to turn the pc off and on several times for it to boot into windows (I can then use it fine and game on it as long as i like even leave it on all night and go to it next day).. if i reset it from windows when loaded it will boot straight up into windows again.. I have done some modifications to the pc such as upgrade the hardware in it etc but it started doing this from when it was standard..
Spec is as follows:
Case: Antec 300 Case with Purple LED Fans
Power Supply: OCZ ZS 750w PSU
CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
Motherboard: MSI Z68A-GD65 Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
Cooler: OcUK H2 Flo CPU Cooler
RAM: 16GB DDR3 Kingston HyperX Genesis 1600MHz Dual Channel Kit
Hard Drive 1: OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive
Hard Drive 2: Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 64MB Cache 7200RPM - OEM
Graphics Card: HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card
Graphics Card 2: HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card
Sound: Realtek 7.1 Channel Sound (On-Board)
Optical Drive: LG DVD+/-RW SATA Drive
I am running it through a 50" plasma tv..
Any ideas on whats causing this?
Spec is as follows:
