strange problem
Permabanned
14 Jun 2005
ive just biult the pc with the following spec and when i go to power up everything turns on fine fans etc but the monitor cant get a signal and the cd drive has the led stuck on and wont open and cant hear the ahrd dricve trying to boot any ideas??
£309.85 x 1 - AMD Athlon 64 3700 Retail / Asus A8R32-MVP Deluxe / 2GB Corsair XMS 3200C25PT Dual Channel Kit - Bundle (BU-028-OK) £0.00 x 1 - Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) CAS2 (MY-079-CS) £0.00 x 1 - Asus A8R32-MVP Deluxe Crossfire (Socket 939) PCI-Express Motherboard (MB-131-AS) £0.00 x 1 - AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - Retail (ADA3700BNBOX) (CP-121-AM)
£18.95 x 1 - Liteon SHM-165P6S-01C 16x16 DVD±RW Dual Layer ReWriter (Beige) - OEM (CD-047-LO)
£59.95 x 1 - Seagate Barracuda 7200.10 320GB ST3320620A ATA-100 16MB Cache - OEM (HD-082-SE)
£74.95 x 1 - Coolermaster Wave Master - Silver (No PSU) (CA-037-CM)
£89.95 x 1 - OcUK Gamer Extreme 178GP 17" LCD Monitor - Black (MO-016-OK)
£39.95 x 1 - Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS)
£119.95 x 1 - PowerColor ATI Radeon X1800 GTO 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-061-PC)
£34.95 x 1 - Creative Inspire 5.1 P5800 Speakers - OEM (SP-043-CL)
£15.95 x 1 - Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM (SC-040-CL)
£2.95 x 2 - Akasa Rounded Ultra ATA133/100/66 IDE Cable (0.45m) - Blue (CB-041-GE) £5.50 x 1 - Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC)
£8.95 x 1 - Logitech Internet Pro Keyboard (Black) - OEM (KB-011-LG) £5.50 x 1 - Logitech S96 PS/2 Optical Wheel Mouse Black - OEM (KB-046-LG) £19.50 x 1 - Silverstone SST-FP52 Silver Aluminium Fan Controller (BB-002-SV)
Connect the graphics card to whatever molex allows connection to the PSU. Just make sure you connect it to the PSU. Otherwise you will not get a signal to the monitor.
As stated previously, make sure you have the IDE cables are the right way round, If there is a light continuously on, this generally means that there cable is the in the wrong way round.
ive plugged it into the first pci express slot display below of what it looks like
PCIEX16_1 big slot
PCIEX1_1 small slot
PCIEX16_2 big slot
ive plugged it into the top one im not using crossfire or anything as i dont have 2 cards have i plugged it into the right one ?
ive deffo got it in the right slot
on the back there is 2 dvi slots ive got it on the right one and using a dvi to vga connector still aint powering monitor up though :S
You have 2 PCI-E slots.
1 blue one PCI-E
Then a PCI slot
Then a 2nd black PCI-E
Common sense would tell me to use the Blue slot when running one card!!!
