Strange problem
20 Nov 2011
Bradford
Hi guys,
Got a bit of a weird issue, hope you can help.
My friend messaged me as his computer wouldn't turn on, the lights were coming on and the fans were spinning but it wouldn't even load to bios.
After asking a few questions, he said that he found a couple of pools of liquid on a couple of the components which he cleaned off. When I managed to go round to his house and have a look, I could see that there were little drops of this liquid here and there on the motherboard and other components, as well as inside the mobo heatsinks.
He smokes an e-cig which he makes his own liquid for which I think is just made up of glucose and food flavourings but his e-cig produces a hell of a lot of vapour and I'm 90% sure is what this liquid that has gotten everywhere is (same colour and consistency).
When taking off the CPU heatsink, there was a collection of a blackish gloop on the heatsink's grill and on the metal CPU clamp and looks like it might have burnt but not sure (could just have mixed in with dust).
The lights that turn on on the motherboard are next to the DIMM sockets and having looked at the mobo manual, it looks like it either thinks there is an overclock on the memory and CPU, which there isn't, or an overvoltage to the memory and CPU.
I'm not sure what options he has as it looks like the mobo might be knackered, although I would have thought a liquid would have completely fried the mobo and other parts and wouldn't turn on at all?
He said he might want to replace the mobo and cpu but doesn't want to spend much as he only bought the pc for £250, but the problem is we don't know exactly what works and what doesn't, which I'm going to test this week.
Do you know what he can do? Is there a special way of cleaning the mobo or do you think it is beyond saving?
His rig is:
i7 920
gigabyte x58a-ud3r
16gb Corsair XMS3
Sapphire 7950
Thanks
cmd-
Update: My friend has scoured the internet and found a couple potential fixes which I'm going to try tonight.
Apparently the motherboard needs a GPU plugged in to turn on at all and so we are going to try an old 8600gt in case it is the 7950 that's at fault, possibly damaged by the liquid.
The only other possible fix is to reseat the CPU but can't see this having much affect.
Anyone have any ideas that I can try or have any experience with this mobo?
Thanks
cmd-
try with one stick of ram in and see if it boots, if it fails try another.
try a clear CMOS as well and you can try the gpu in another PCI E slot in case its a faulty PCI E lane
I would suggest if the water is caused by his e-sig he doesn't smoke it near the PC or the same room as the PC lol
is it the lights that are right next to the memory slots or the top right of the motherboard which come on?
I have had a quick look through the manual and there is quite a lot of lights on it depending on volage, OC and temps
in the spooler is a screen shot of the page from the manual which may help you find what the lights are referring too.
fcEcUcqg6PHD33mH
hope this helps
Hi,
Thanks for the reply ED209.
We tried resetting the CMOS and tried with just one stick of ram but to no avail.
I'll try the different PCI E slot as well as a different GPU tonight.
I checked the mobo manual as well but couldn't make sense of which lights pointed to what, but in the 'Overvoltage LEDs section, it's the lights to the right of the DIMM slots which are yellow.
Under the 'Overclock LEDs' sections, those lights are red. No other lights are turned on on the motherboard.
I'm still pretty sure that it's the vapour from his e-cig that's caused it, but trying to find out what damage it's caused is going to be the sticking point.
If anyone is a 'cloud chaser' with their e-cig, I seriously recommend not smoking it around electronics!
ok, so from your first post you have said there is no OC on the cpu but the lights indicate there is a OC.
one more thing you could try if all else fails is remove the cmos battery from the mobo and disconnect the PC from the mains for 30 mins or so then put the battery back in and then connect it back to the mains.
the CPU overclock LEDs should be off if there is no OC on the cpu
The guy who my friend bought the PC from was pretty sure he didn't overclock it but it's 4 years old so couldn't be certain.
Unfortunately when reinstalling the heatsink, one of the plastic clamps broke (after an hour of cleaning the damn mobo!) so couldn't go any further.
My friend's going to buy a new heatsink today so baring any other annoying issues, we might be able to test it tonight.
