Good forum I am new and I'm looking for a solution that I can not find anywhere I have a z170 xpower gamming titanium, the issue is that when I switch from fixed voltage to adaptive voltage, I get those errors that I see in the red boxes and I do not know what to do I must have an i7 7700k delid with fixed voltage all right but when i use the same configuration and i put it with adaptive they leave those errors that are not due to them, thank you very much.
voltage adaptative ...The cpu does not work at 5.3ghz either(cinebench)
Not because I get those mistakes
voltage override The cpu works at 5.3ghz(cinebench)
