- 17 Aug 2023
- Istanbul-Turkiye
Hello Friends
I recently built a new case and added the AMD Radeon RX 6700 10GB graphics card from my old system, which I thought was still sufficient for me. However, when I plugged the display port cable I had between the new case and the monitor, no image appeared on the screen even though I selected the display port output on the monitor.To solve the problem, I bought an HDMI v2.0 cable and connected it between the case and the monitor, and the screen did display. However, I have two problems...
1. Why is there no display on the screen when I plugged in the Display Port cable after the case upgrade, even though I'm using the same monitor and graphics card? Would using a different Display Port cable solve the problem? If so, which brand do you recommend?
2. When I plug in the HDMI cable, the maximum screen refresh rate is 60Hz. The maximum refresh rate is listed as 60Hz in the operating system's advanced display settings. Why am I not getting a 144Hz refresh rate option even though I'm using an HDMI v2.0 cable?
Thanks
https://hizliresim.com/ottf872
Thanks
