Strange RAM Voltage readings
Permabanned
13 May 2011
I Have 8gb of this ram ---> http://www.ocztechnology.com/ocz-ddr3-pc3-10666-gold-low-voltage-triple-channel.html which i got off overclockers.
Ive had it for a while know and all seems fine but i recently got a new cpu cooler so i attempted to overclock my 1090t.
I found that even on fully stock settings i would get comeplete lock ups under prime 95 testing and im pretty sure its the ram.
So i checked the ram voltages and AMD overdrive said i was on a 1.5750 voltage but the bios said 1.5 volts. This is strange as this website ----> http://www.ocztechnology.com/ocz-ddr3-pc3-10666-gold-low-voltage-triple-channel.html says that the Ram i have is at stock 1.65 volts.
Has my ram been undervolted and should i turn it up to 1.65?
The memory you've linked to has been tested up to 1.65V so if you're having stability issues i would increase the memory's voltage until things become stable - obviously 1.65v being the max (if it's a memory issue.).
There nothing wrong with undervolting memory as long as things remain stable.
Did you set the memory up manually - you may want to check your timings/frequency as these too could be running under stock if you left settings on auto?
Timings are fine, upped voltage to 1.545 in bios but still cant run a prime 95 on fully stock cpu settings without a complete freeze.
As above, you may as well knock the memory up to its rated voltage so you can rule out lack of juice as being the problem.
Plec meant lack of juice for the RAM not lack of juice for the whole PC.
Thanks Surveyor, my reply should have been a bit more comprehensive.
Oh sorry. Ive upped it to 1.65 and seems the problem is fixed, going to drop it down until the problems starts again
Great - hopefully the increased voltage has solved your stability issues.
I would test each voltage drop for a couple of weeks as memory issues can be very intermittent.
... Anyone? Just wondering why you would want to lower RAM voltage below recommended?
Less heat, perlongs life of memory (in theory), slightly lower power consumption and with some setups - notably Sandybridge - if your clocking the system it's recommended to have the voltage below 1.58V.
It's always good to get the lowest possible voltages for core components such as memory and CPU - mainly for temps and longevity of part (and manufacturer's recommended settings/guides)
