This possibly should be under the motherboard thread, but since it could be something else, thought I'd better post here...
Just built a system with a Gigabyte Z87X-UD4H and i7-4770k. Everything installed fine and was going well till I attempted some overclocking. The 4.3ghz mobo preset booted up fine, but was running too hot, so I tried a lower OC. That wasn't liked, and ended up in a re-boot cycle. Eventually got that sorted by flashing to the latest F8 bios. However since then, the computer has randomly switched off 3 times (and then started itself up) whilst doing fairly normal things. On the first 2 occasions, I was installing something from disc, which had me thinking it might be related to the optical drive. However the 3rd time it switched off whilst copying files from a usb drive and browsing the web. There's no indication in the windows events log; the mobo debug code goes to "AO" (all normal, I think), and everything else appears ok.
Really stumped here, and somewhat annoyed as there's nothing obvious.
Specs are as follows:
Corsair AX860 psu
Gigabyte Z87X-UD4H
Intel i7-4770K cooled by Phanteks enormous CPU heatsink (temps are all fine)
Teamgroup Vulcan 2x4GB 2400Mhz RAM (using XMP profile)
Samsung 840 250Gb boot drive + WD green 2Tb storage drive
MSI 290 Gaming
LG blu-ray drive
Creative Soundblaster Z soundcard
Any suggestions appreciated! Thanks!
Corsair AX860 psu
Gigabyte Z87X-UD4H
MSI 290 Gaming
LG blu-ray drive
