- 18 Oct 2002
Not sure if this is a Windows 10 related problem or hardware related.
Thought I'd post here to begin with.
So my PC is not overclocked and pretty much running at stock and stable. When I go to shut down Windows, it shuts down as you expect without any issues.
If I go to restart via Start Menu, then Windows goes to restart, the monitor goes blank (as if no signal) and my case fans ramp up to 100%. I can't do anything in this state and have to hold the power button on my case in order for the PC to turn off.
When I boot back up there is no disk check service due to an incorrect shutdown, so it looks like Windows closed itself fine prior to screen going blank as per above.
Anybody come across this before?
