Strange snow effect on monitor
2 Jan 2014
My son has a gaming setup specs below, he's just bought himself a gaming/smart monitor Samsung Odyssey g6 240hz
Ryzen 5 2600
3060ti
MSI B450 vdh pro
A strange thing is happening though it's barely noticeable unless you know it's there which he does, like small dots almost like snow trickling down the screen in a line about 1cm width, this appears to happen every few minutes. I have had the monitor on my pc and it does not happen, any ideas what this could be. He's tried different cables, hdmi and display port so I'm confident it's not the monitor. The odd thing is it didn't happen on his lg gk32 650f 144hz monitor.
have you figured out how to fix it? i have the same issue :/
Sorry I took so long, No we believe it may be the motherboard, it's pretty basic(cheap), so I think its the combination of high end GPU and CPU coupled with the PSU and MB being pretty basic. I put the monitor on my setup for a day and it seemed to work fine, whats your setup?? Could you confirm any of what I have said.
actually, me and a redditor i met online believe we found a way to fix it! you need to open the nividia control panel and go to set up g-sync or just enable g-sync, i checked out all the boxes there and enabled it in windowed and full screen mode and my monitor works fine now!!
regarding the setup, i have B760 GAMING X DDR4 (not sure if i said it correctly) and geforce 4060 Ti, so i presume it is pretty powerful (as far as ive been told at least)
