- 19 Aug 2004
- Stockton-on-tees
Ok when as soon as the pc has started and say you go to open IE it then locks up, it will open and start it ok but then the blue bar at the top of it goes a lighter blue like when you have clicked on something else. It does the same if you open a folder too then the only way to get it working again is to ctrl alt del and end task or switch to.
It just sits there and right clicking on the task bar or in the page doesnt do anything, after that first startup attempt its fine all day. Any ideas as its just started playing up this last week.
