I've got some strange things happening with 3DMark06. I wonder if someone would care to speculate on what might be going on here.
Basically when I run it I usually end up with a score somewhere around 12500. And the framerate in the first test (return from procyon?) is usually around 85 at the start. But sometimes when I run it this drops right down to 22 or so and my score drops to around 4500...
Now... when this happens I can usually "fix" it by opening my case and wiggling the Graphics card around a bit. I also noticed a while back that a couple of the gold contact surfaces on the "pins" of the graphics card seem to have little bits missing at the ends... (I can probably take a photo of this if it will help... but they're basically just a little shorter than the rest - both only on one side of the board)
Is it likely that these might be losing contact in some way with the PCIE bus and that's why the performance goes way down? If they did lose contact would the card keep working but slower? Or is there something else going on here?
Any thoughts please? This is getting a bit annoying.
