strange voltage for barton?
Suspended
30 Dec 2003
currently got my barton 2500 non-mobile running on 1.35volts (nf7-s) 10.5 * 166mhz
is this abnormal do you think? to have it running at stock speed 1800mhz on such a lower than normal voltage?
yes barton stock speeds are 1833mhz as standard BUT its usually at 1.65v, only mobile cpus run at 1.45v and some run at 1.35v.
just means it a good one mate
Lucky lucky devil, you may have been sold a mobile without you or the seller realising it:)
Is it multi-unlocked? I think non-mobiles need modding to unlock so if you can change the multiplier in the BIOS then it's the real deal!;)
