- 8 Sep 2006
Hey guys
Built a pc other week and well, when the computer boots up (sometimes not allways)
I get confronted by this:
(image done in photoshop to represent what happens)
The computer will then reboot itself and try again, if that dosnt work i get the "start windows normaly" or last good config etc...
I try last good or normaly, and it (sometimes) loads without the messed up lines all over the screen, other times it dosnt work
Im dead confused,
Spec:
(totaly standard no oc)
core 2 duo 2.13 2mb
Leadtek geforce 7950GT 512MB
Gigabyte GA_965P_S3 775
250gb WD SATAII 16mb
Corsair 800mhz DDRII
Samsung Syncmaster 19" DVI+Dsub
I personaly i can only imagine it being the GFX card + mobo which might be arguing and creating the strange boot mess?
If anyone has any ideas i would be very graitful!!
Cheers
Im dead confused,
Spec:
core 2 duo 2.13 2mb
Cheers
