Strava bizareness
18 Oct 2002
Riding my bike
So, same segment, same bike, I'm the same weight. But 2m 5s faster aaaannnnndddd I did it using 77 less watts?
How?
I know that the power estimation is shonky, but that's just bizarre. Can anyone explain what is going on?
Without more details about the segment, it could be explained by headwind for slower time and tailwind for faster time.
The average power over a segment (particularly a long one) doesn't tell the whole story. Lots of high peaks and lows in your power and therefor speeding up and slowing down will give you a slower average speed than a constant power/speed - because drag increases exponentially with speed and also it takes more force to accelerate a mass than it does to keep it at a constant speed.
Also, I think the power calculation shown there is moving power (not including stopped time) but the time includes and stop time so could make quite a difference if there's lots of junctions on your segment.
Interesting - no stops. It's basically a lane that turns into a track through a bluebell wood. Steady climb. I guess without a power meter any figures are going to be a bit bizarre. I'm just surprised by the discrepancy!
if the GPS glitches it''l just draw a staight line when it can't 'see', and guess.... that would be more down to connectivity than the app, per-se.
I don't use Strava, use mapmyride, but had a thing where the phone must have dropped out signal for 2 mins and decided that I'd covered that blackspot instantly, thus giving me a silly top speed and a better average speed for the ride.
