STREACOM DA2 MINI-ITX
  • Thread starter Thread starter Uzu
  • Start date Start date
Uzu
Uzu
28 Mar 2018
Yorkshire
I've just bought this case and knew i'd be disappointed by the only 2 slot GPU support, turns out if you like ripping out dust filters like me the bottom of the case opens up and I could comfortably fit a 3 slot in there without issue.
Hardware Compatibility:
  • Max CPU cooler height: 145 mm
  • Max GPU length: 330 mm (220 with an ATX PSU)
  • Max GPU height: 50 mm (dual-slot)
  • Max GPU width: 150 mm
So for those considering a DA2 if you take the filter out the max width of 50mm is well off what you could fit, more like 65mm without choking the fan.
Case with measurements.
https://ibb.co/njTLC6K
Hey how did this go? Did the GPU fit nicely through the bottom with no dust filter, and how are temperatures?
This is exactly what I am considering doing. Also how does it look?
