OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to introduce the new Streacom F12C series of HTPC cases, the first that Streacom have made with ATX motherboard support in mind. Added to that is the full ATX PSU & 310mm VGA card support, 4mm premium aluminium panels, a wealth of fan/drive and watercooling adapability and the premium finish quality you've come to expect from Streacom throughout. Stock is very limited and should arrive in the next week, so I suggest preordering to avoid disappointment!
Streacom F12C Aluminium HTPC Chassis - Black @ £199.99 inc VAT
The F12C is our first case designed to accept all standard ATX hardware, but of course being Streacom, the design is anything but standard. The ultra-minimalist exterior is made from 4mm thick premium grade extruded aluminium panels which are sandblast finished to create this simple but timeless design.
The unique design isn't just skin deep, we have developed a new drive and fan mounting system that does away with traditional fixed location bays, making this case incredibly adaptable and configurable. Drives and fans can be mounted anywhere along both sides of the case and at virtually any orientation. This allows you to mix, match, and perfectly position drives and fans for optimal cooling and hardware compatibility.
There is an additional upper mounting rail which is designed for fans and water cooling radiators, and combined with side panel venting, provides incredible amounts of cooling potential. Fan grills have been specially chosen to filter dust whilst maximising airflow and can all be externally removed for easy cleaning.
The open internal structure and flexible design allows for oversized PSU's, 310mm long expansion cards and 140mm + 2 x 120mm water cooling whilst still maintaining a footprint of just 420 x 320 x 184mm, making it perfectly suited for the high end home system.
Features
- The entire exterior, including the power button is made of premium grade extruded 4mm thick aluminium
- With ample venting on 3 sides of the case and dedicated upper mounting rails for fans/water cooling, the F12C can quietly cool even the most powerful gaming systems. Easily removable fine mesh grills filter air without reducing cooling performance.
- Minimalist styling and the use of high-quality materials combine to form a design that is classic and timeless
- With its open internal structure and innovative universal bracket mounting system, the F12C not only supports virtually all hardware, but is also extremely versatile, allowing users to mount hardware in optimal positions.
- With over 5KG of aluminium used, this design is extremely strong and durable.
- The user manual contains clear and precise illustrations which show every step of the installation process.
Specifications
- Chassis Material: Extruded & Milled Premium Grade Aluminium (6063)
- Colour: Black Anodized & Sandblasted Finish
- Motherboard Compability: ATX, Micro-ATX, Mini-ITX
- Hard Drive Support: Variable Configuration for up to 24 x 2.5" or 12 x 3.5"
- Optical Drive Support: None
- Cooling: Variable Configuration for 80, 92, 120 & 140mm fans
- Front Ports: None
- Expansion Slot: 7 x Full Height Expansion Slots (Max Length 315mm)
- Dimensions: 440 x 320 x 184 mm (W x D x H, Including Feet)
- Power Supply Support: Full ATX, no length restrictions
- IR Solution: IRRC or FLIRC IR Solutions
- Net Weight: 4.4KG
Only £199.99 inc VAT.
ORDER NOW
Streacom F12C Aluminium HTPC Chassis - Silver @ £199.99 inc VAT
Features
Specifications
- Colour: Silver Anodized & Sandblasted Finish
- Front Ports: None
- Net Weight: 4.4KG
ORDER NOW
Features
Specifications
- Front Ports: None
- Net Weight: 4.4KG
ORDER NOW
Features
Specifications
- Front Ports: None
- Net Weight: 4.4KG
ORDER NOW
