I think I've made a thread here before about an ITX build but I think I have narrowed down my case search to either the FC7 or the FC8 EVO. The FC7 is cheaper but then the cost of a CPU cooler and exhaust fan come in to it and remove that benefit which means it comes down to whether the FC8 EVO will take the 77W capacity of the i5. It says it will, with various cravats*.
If I did go with the active cooled case what 80mm fan should I go for and what CPU cooler would be the best bet for as quiet as possible running?
On the same vein, reading Bordens thread, vibration transferral appears to be an issue when mounting a 3.5" drive. I'm going to be using this to store a lot of photos so will probably end up with a 2TB drive in the machine and then an external drive attached for backup. One way to get around this (I may end up having the machine on 24/7) is to set the 3.5" drive to turn off when not in use and have everything I normally use on the SSD so it's not a major problem. However are there any other cases this sort of size and style that have a better 3.5" ability?
Lastly, what board would be best for me to put in it? It needs to have a display port or another ability to output 2560x1440 and have a decent wifi reception (need antenna for that?). I'm not looking to over clock so just a cool, stable board with the above two abilities would be good. The ASRock Z77E fits the bill I think but any cheaper boards recommended?
*No, not those things you put round your neck, the other one I can't remember how you spell...
