Stream audio from PC to Reciever wirelessly
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi there.
I've got the Denon Picollo Amp, but as I've only for 3.5mm jack on my PC it won't work with the amp, so is there software I can use to play everything from the PC wirelessly to the amp?
Thanks
If you are not using the RCA analogue input on the Denon, use that. All you need is a 3.5mm jack to RCA cable. Something like this, unless of course, you can't use a cable for some reason.
There aren't any wireless options on the DRA-N5, so cable or nothing it would seem.
QED U-Play bluetooth streamer?
Looked at ome myself, but instead use a HDMI lead for the laptop and a 3.5mm-phono adaptor for anything else.
