I'm hoping I can get some advice.
My current audio setup is a Monitor Audio A100 hooked up to a pair of B&W 685 S2 speakers.
I mainly use AirPlay and the optical input from my PC, also occasionally DLNA to steam FLAC files from my NAS.
The A100 sound quality is fantastic and very composed. However I have recently been feeling that I would like a little more bass with some music - nothing excessive though. I was wondering whether replacing the A100 with an amplifier that has dedicated bass and treble controls would be a way forward?
I was looking at the Yamaha R-N402D and R-N602D. These are classed as a network receivers rather than amplifiers, however from what I can see, they are both. They also have all the connectivity of the A100 with the addition of Bluetooth (with AAC support), a radio (FM, DAB and internet) and quite a few other features.
My questions are:
1. How would the Yamaha R-N402D or R-N602D compare to my Monitor Audio A100 in terms of sound quality?
2. The Yamahas are classed as a network receivers - I always thought that a network receiver was a separate component that you hook up to an amp. As this is an integrated device - would it deliver inferior sound quality?
3. Are there any other amps that I should consider for £300-400 - I don't mind buying used either.
Thank you.
My questions are:
Thank you.
