Streaming/Android box for Kodi
22 Jul 2006
Hi All,
Looking for a streaming box/Android box up to £50 that I can load Kodi and stream 1080/720 movies with please?
Idea is it will be housed in a cupboard with an AV receiving and will be projected on the wall.
Many thanks
To be honest i wouldn't go with any the cheapo boxes you really wanna be looking at entertainment box or minix and push your budget little more. You wanna be getting the updates from the supplier and good online support. There is many clone android boxes around at min. I might be selling my T8-V3 from droidsticks. Nothing wrong with it all im only upgrading to the shield so i can add more storage via usb and everything on the shield has a higher spec. Even though my box is quad core plays full size 1080p remuxes 20gig plus and supports 24FPS
Thanks guys, reason I have £50 is have this amount in cex vouchers.
There is an option to buy a firestick on there, they also have an M8 quad core box (B grade) for £35, worth a punt?
If that was me id go for the stick for the sole reason more users and better support if you get stuck. That's why i went with Droidsticks for my android box. Out of the box updates good support and no clone box
