All you need is a decent controller for this. A USB Arcade stick or gamepad like a Sega Saturn style one.
The Official Street Fighter IV Fightpads are quite nice, the d pad has lots of movement and i found it very easy to use, should work nicely with the pc version to i would think![]()
Taito Type X²
* OS: Microsoft Windows XP Embedded SP2 [3]
* CPU: Intel Socket 775 CPU. Supported CPUs include Celeron D 352, Pentium 4 651, Intel Core 2 Duo E6400
* Chipset: Intel Q965 + ICH8
* Video output: 680x480, or 1280x720
* RAM: 166/200MHz DDR2 SDRAM. Supported capacities 512MiB, 1GiB, 4GiB.
* GPU: PCI Express x16-based graphics. Supported GPU include ATI RADEON (x1600Pro, x1300LE) or NVIDIA GeForce (7900GS, 7600GS, 7300GS)
* Sound: Onboard Realtek HD 7.1 channel Sound (supports add-in sound cards)
* LAN: 1000BASE-T 10/100BASE-TX
* I/O ports: 1x JVS, 4x USB 2.0, 1x serial (max 2), 1x parallel port, 2x PS/2, 2x SATA
* Audio inputs: AKG C535EB Stage Microphone, line-in (Surround 7.1)
* Audio outputs: 7.1, SPDI/FX
* Expansion Slots: 1x PCI Express x16 (used by video card), 1x PCI Express x4, 2x PCI
* Storage: SATA2 Hard Drives
As the name implies, Type X² is a natural evolution of Type X and X+ that allows the use of newer PC technologies introduced after the unveiling of its predecessors. Like its predecessors, the specs of Type X² are comparable to that of a contemporary PC.
Wikipedia
It looks like it was made 5 years ago so shouldn't be a problem for most PCs to run.
To be honest the game's semi cel-shaded style could easily have been been done years ago, just obviously with a less refined look.
Oh and Turbo was never released for the MegaDrive. It was Special Champion Edition.
what was the difference between turbo and special champion edition?Im using the 360 pad in my pc, dpad sucks so hope i can get away with it.
It was a long time agowhat was the difference between turbo and special champion edition?
Well considering the specs of the Arcade board that this game was built on.
So yeah, most modern systems these days and from within the past few years should run this game no problem.
The King of Fighters XII will be developed on this board too, though the game will still keep to good ol' 2D sprites and backgrounds.
So arcade machines are basically just PCs now? Oo
