Street Spirit
Fretboard fingering?
Hold an Am chord and use your little finger to hold down the D note on the B string, then lift it, then lift your index finger when you need to play the open B string. For the Em chord, and the C chord do the same thing, it's just a bit more of a stretch.
Do you need pictures?
Yes please.
I normally hold the following position
Asus4, A minor, Asus2
Csus4 (I think - C but holding 3rd fret B string with little finger) Cmajor Csus2
E minor but hold the same position on the B string as you did for the C part
Yea, best you practice the fingering while strumming to start with. That's the easy part.
Then you just have to work on alternate picking and getting the timing right for picking, which I still can't get 100% right all the way through.
Does anyone know how to play the G and E bit's at the end? the "immerse your soul in love bit".
