- 30 Mar 2007
- Essex
Guys what do you use to stress all 4 cores ?
I use OCCT. Easier to configure than Prime and it looks better.
I havent looked at your link but easier than prime ?
unzip, execute and click on a few windows that pop up and your away. Prime is hardly tricky to operate !
orthos was built in the dual core era, the latest version of prime95 stresses all 4 cores as default, the only setting that needs changing is 'round off checking'
Although you will have to select which test you wish to run: large/small fft's/blend
Small fft's for CPU stress test.
