- 22 Nov 2013
- UK
Hey Guys,
I am currently having an issue where my PC turns off during a stress test using RealBench. After 4-5mins, its pretty consistent. The GPU is new. I ran the stress test as the machine was randomly powering down while streaming and playing games. Now I can reproduce the power down with the stress test.
I am not trying to OC the machine, just to get it running at stock to begin with. It was running an MSI GeForce GTX 960 Gaming 2048MB GDDR5 PCI-Express Graphics Card before the 1080ti below with no issues. The powering off only started when I bought the 1080ti.
Here are my PC Specs:
CPU: Intel i7 6700K @ 4.0GHz
MotherBoard: Gigabyte Z170X-Gaming 5 BIOS Version F21.
Memory: 2 x 8GB DDR4 (Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel)
GPU: Nvidia GeForce Aorus GTX 1080ti (GPU Boost Clock 1683MHz | Memory Clock 11010MHz)
PSU: Corsair GS600W
- XMP Is enabled, was disabled, but I enabled this last night. It hasnt affected the power off issue but it has improved performance of my memory, as it was running at 1066MHz now idles at 1500MHz.
- CPU Vcore set to Normal (1.230v).
- Dynamic Vcore (DVID) set to +0.070v.
- All other CPU Voltage options set to auto.
Power Loading Feature
Now this board has something called Power Loading which acts like some power load balancer type thing, not entirely sure. It has 3 settings Auto/Enabled/Disabled. When the PC powers off in the stress test, it is set to Auto. If i set it to Enabled the stress test completes and there is no power off, BUT parts of the stress test seem to crash, the rendering app LuxMark i think its called, stops responding and the monitors flicker, both of which doesnt happen on the Auto setting.
Now the test completing doesnt fill me with confidence as parts of the test crash out themselves.
Worth noting that changing the setting this feature has an effect on the stress test:
Auto - No screen flicker, all apps run ok, but powers off after 4-5mins into the stress test.
Enabled - Screen flicker, Luxmark App within RealBench test crashes, but no powers off after 4-5mins into the stress test, and stress test completes "successfully" after 15mins.
Here is a youtube video of the Power Off (Power Off actually happens at 4m30secs) as it normally happens during a stress test. Ignore the sound its all background noise from the family.
Motherboard Manual
Currently the Power Loading is set to enabled and I am going to run some streaming/games and see how it behaves.
My thoughts are to replace the PSU I have with this one and see if that resolves the issue, but everything I have read states that my current PSU should be ok, unless of course it has a fault somewhere.
Ive never had to adjust voltages etc before to get things working/stable. So I am new/novice to all this and would appreciate any assistance from someone who has more experience with this.
Kind regards,
Swart Skaap
PSU: Corsair GS600W
Motherboard Manual
Kind regards,
Swart Skaap
