I replaced my SuperDrive with an SSD. During the process of removing the SuperDrive I managed to strip the screw head of one of the tiny screws closest to the edge of the MacBook. I was still able to get the SuperDrive out of the MacBook as the screw in question was raised just enough to be able to slide the retaining SuperDrive clip out from underneath it.
Should I be concerned and still attempt to get the stripped screw out?
I was able to fit the SSD, in a special caddy, by attaching it to the case with 4/5 of the screws and it seems pretty secure.
I tried a lot of different methods to get the stripped screw out including, a rubber band, a different sized phillips screw drive head, turox screw driver, super gluing a screw driver to the stripped head. But nothing gave me the traction to get it out. I suspect the screw head may have been slightly damaged to begin with, but couldn’t tell as it is in such an awkward location.
On a side note, the macbook I’m upgrading was, a mid-2012 model, had stickers on parts such as the SuperDrive and battery that had the dates 2014 on them. Is it just me or this a bit odd? I bought the laptop second hand so don’t know if anything has been replaced?
