Because of the constraints of my case I have had to install an parallel interconnect for my SLI GPUs. The problem is the port on the interconnect that I want to use as an output is right in the path of the HB SLI bridge as below
I have taken the outer casing over the bridge off and unplugged the LED obviously. That just leaves a very flat board which doesn't interfere with compression fitting or obviously the tube once it's connected.
It looks ugly as hell, but I'm pretty sure it will work fine. Does anybody have any experience of doing this successfully? Once I've put it all together I'll have to drain the system if I want to remove the SLI bridge again.
